wapiticountry
Oct 29, 2022Explorer
What happens when you turn on the faucet without the hose? If that is what your shower hose connected to, it appears to be a back flow preventive or some kind if water saver. If the water still only trickles with the hose off, remove it and see what happens. Those type of fittings can clog and stick due to debris and calcium buildup . Do you get good water flow elsewhere? If not look for whole house filters. If your low flow only happens with the on board pump and not when hooked up to domestic water hose, there is likely a clogged filter at the pump.
