lonfu
Apr 23, 2017Explorer
lower compartment latch or slide bolt replacement
Ok, so just bought a 99 pace arrow 35U for $6k. I need to replace 12 of the 20 slide bolts on the lower compartment doors. Sadly, the latches are mounted on the inside of the door frame rather then on the outside like many later models. Rather not have to pull apart 10 doors...... Has any one tried simply routering out a port near where the latch is and servicing it through the port? The latches are set with a nut and bolt set.
Any suggestions on a hole size for the access port?
Figured I'd make some aluminum plates to go over the holes with silicon to seal up. I was thinking making a clamp on temp plate and using a counter trimmer so I could do it right on the coach. Figure once I make the plate, it will take me less than 2 mins each to create an access port to replace the broken slide bolt. I already have ordered the bolts.
Any suggestions???? has anyone tried this?
