Artum_Snowbird
Nov 20, 2015Explorer
This is what the online owners manual says:
Pedestal
The dinette can also be converted into an additional bed if required. To convert, lift the table top off
of the two support posts. Remove the support posts from the floor and lay them down between the
seats. Insert the table top between the seats on the ledges provided. Loosen the seat cushion from
the Velcro fasteners and slide each together to form the bed. Reverse this process when
reconverting to the dinette configuration.
Wall Mounted
This dinette can also be converted into an additional bed. Lift the aisle side of the table and and
pinch in the pins on the table leg to collapse the leg. Unhook from side wall and swing into place.
The table supports on the dinette base. Loosen the seat cushion from the Velcro fasteners and
slide each together to form the bed. Reverse this process when reconverting to the dinette
configuration.
2010 manual
hope that helps..
Pedestal
Wall Mounted
configuration.
2010 manual
hope that helps..
