tenbear
Aug 23, 2015Explorer
Mine is also wired the same as Mich F's. When I pull the fuse the only thing that happens is the lights on the monitors go out, no noise. Once the fuse is unplugged, the monitors have no way of knowing if the battery is good or not.
You don't say if you are plugged in or not. If you are, the converter may be still supplying 12v power.
38,782 PostsLatest Activity: Sep 02, 2026
