tenbear
Aug 23, 2015Explorer
It depends why your battery is dead. If it is discharged due to a lack of charging, and your converter is good, The battery could be just discharged. It may or may not be dead, unable to hold a charge. Have you tried charging your battery with a different charger or having it tested?
On the other hand, your battery may be dead because of a problem with your converter or it's associated wiring. You may need a known good battery to determine if your converter is good or bad.
38,782 PostsLatest Activity: Sep 02, 2026
