DanTheRVMan wrote:
Terryallan wrote:
DanTheRVMan wrote:
The stoves LEAKS. They all do.
I got scared once due to the smell. Spoke with a tech at stove manufacturer. I do not know if they want it this way, it is a non problem they live with or what, but it leaks. Turn the propane off when not in use I guess.
I smell it at times and hope the tech has not steered me wrong.
Been camping for 30 years. Have never once had a stove to leak, Never smell gas in the TT unless lighting the stove when I turn iot on. I'm thinkin, your tech ain't as smart as he wants you to think he is. Or maybe he don't like you. Or he just don't want to fix it.
The stove is a very low pressure system to my understanding. I am not certain, but I think it is roughly 0.5 psi
On at least some stoves they have a pressure relief system from what I have been told. These pressure relief valve release gas occasionally - not continuously.
Some people can smell these occasional low level releases and some can not from what I was told.
You go with that. If it helps you to sleep, and it may well help yopu to sleep
