downrivers's avatar
downrivers
lpg detector
My lpg detector has the low voltage light on and makes a lot of static when it is plug into 110 volts but when I turn on the 12 volt system it stops. Any ideas
  • The 12 volt system works fine. When I disconnect the battery and plug in the 110 the detector works normal then after a few minutes it switches over to low volt light with a lot of static.
