homerbwExplorerApr 28, 2016Macerator hairI'm having a lot of hair building up in my portable macerator. It is slowing down the grinding process and even forcing me to remove it and use a small tool to grab the hair and remove it. What do t...Show More
Big_KatunaExplorer IIApr 28, 2016You should take your macerator apart once a year or every other year and clean it and check the impeller.I have found that when hair has built up, there is usually a broken vane on the impeller. (not related)Parts are available from West Marine or Amazon. The impeller has a part number on it and there are different ones.
