If it's as you've described, then it's a pretty simple operation. Plan on it taking you about 60 minutes and about $30 in parts.
1. Close knife valve.
2. Remove all wiring from the pump.
3. Remove the 3" semi rigid flex hose.
4. Remove the bypass hose.
5. Remove 4 screws attaching the pump to the coach.
6. Remove the pump assembly.
7. Take the pump assembly apart. (see link below)
8. Inspect ALL interior parts. The stainless two piece grinder is usually the one that gets the hair and gunk attached to it.
9. Inspect and replace, if necessary, the impeller. This is your pump mech that pumps the fluids through the macerator.
10.Reassemble the pump assembly and reinstall it the opposite order of removal.
11.Attach all wiring.
12.WITHOUT turning the pump ON, slowly open the knife valve and check for leaks. Tighten as necessary.
13.If no LEAKS, turn the pump on and flush away.....
It's best to have a repair "kit" before you begin. The big kit will be about $50. There's a gasket between the two halves of the pump itself. This gasket has a tendency to break if you're not careful. You can make a new one by buying a sheet of gasket material for about $6 at NAPA....If you clean the macerator annually as part of your yearly maintenance, you'll not need the impeller kit, but if this is your first time in there, I'd buy and use the $50 kit....Dennis
Jabsco Service KitYou can google the part number and maybe find it less expensive. I simply used the above as a reference...feel free to PM me is you have a particular question. I've installed several of these pumps and service mine yearly....D
