BigSkyBob
Apr 05, 2015Explorer
Executive wrote:
I'm not sure what a sewer master system is, but I've had a macerator system in my last two coaches and it is a 'must have' for any future coaches. Some pros and cons:
Pros:
Easy to dump
No mess - no gloves no spills
Can dump almost anywhere there's a bathroom available.
Can pump up to 100' away and 8' in elevation.
Cons:
Takes longer to dump.
More expensive than a stinky slinky.
Needs to be cleaned annually. More often if someone has long hair.
The last one can be mitigated if you use a strainer in the shower which we do. But I still remove and clean my pump as part of my annual maintenance. Simply remove the pump, remove 4 screws, clean the impeller and reassemble...Dennis
Dennis has it right, my procedure as well. Love the Sani-Con system.
38,771 PostsLatest Activity: Apr 14, 2026
