Executive45
Apr 05, 2015Explorer III
lanerd wrote:
Dennis... when you say clean the impeller....are you talking about the actual neoprene impeller or the metal blades? On my macerator, only problem I had with the impeller were broken vanes and had to be replaced twice in six years....however, it was the metal blades got gummed up with hair.
Ron
Yes, the metal blades. The rubber impeller simply pumps..usually you can get 4-5 years out of them, depending, of course how often you use the macerator.
BTW...almost all macerators have a grey water bypass so it can be left open when you're camped with a sewer hookup.
Another tidbit for those that have them...get a 10' piece of 1 1/4 PVC pipe and split it lengthwise. This allows you to encase the sewer hose inside and protects it from laying on the gravel, or you can put both pieces together to protect the top and bottom of the hose. Doing so will prolong the life of the hose and the PVC doesn't take up much room in your rig....D
38,771 PostsLatest Activity: Apr 14, 2026
