Effy
Oct 30, 2014Explorer II
unless you have a bypass the water will not flow past the pump and essentially do nothing by leaving the valve open. I am planning on installing a bypass with a ball valve so I can do it via gravity or pump. Just remember, it will drain slower as it's a smaller dia hose and the bypass is even smaller.
38,777 PostsLatest Activity: May 24, 2026
