wa8yxm
Oct 30, 2014Explorer III
There are basically two macerator systems, a few different companies, ONE pump style (pump motor and pump)
Sani-Flo includes a small "Bypass" line which you can see on the outside of the pump housing that lets gray water drain past the pump.
Flo-Jet does not
I do not know about your system
Water will NOT flow through the pump itself unless it is running, the type of pump will not allow it... But the bypass hose will bypass if you have one.
Flo-Jet does not
38,777 PostsLatest Activity: May 24, 2026
