It has been raining constantly in Wisconsin so out side work has been difficult. I replaced broken exhaust hangers. I washed the passenger's side then used Scrubbing Bubbles to clean it again. Next I applied Meguiar's Ultimate Compound to remove oxidation and clean the fiberglass. Finally I applied 2 coats of Nu Finish. I got the top half of the driver's side done using the same process.
I thoroughly cleaned the inside and installed a new stereo system. I relaced the rubber seals on the fresh water tank's connections and fixed the level indicator lights.
