full_mosey
Aug 26, 2013Explorer
smlranger wrote:
So, maybe the 6 amp charger is not working but it is fairly new. Or, it is reading 12.2 volts and thinking that is a full charge because it is switching from 'charge' to 'maintenance' after about two hours.
Let's say that your 8Ds are 50% discharged at 12.2V. Your 8Ds are 245AH rated, so a pair would be 245AH discharged.
If, and a big if, the 6A charger could hold 6A, it will take a minimum of 245/6=41 hours to recharge. That is unless you are using the batteries at the same time.
You could be using more than 6A and the charger cannot keep up, much less charge the batteries.
HTH;
John
HTH;
John
38,769 PostsLatest Activity: Apr 24, 2002
