Google works wonders, if you use it.
ME2012-20B Inverter/Charger, 2000 Watts, 12 VDC
Same as ME2012 but also has two 20 amp AC breakers pre-installed.
The ME Series Inverter/Charger from Magnum Energy is designed specifically for rugged mobile applications. The ME Series is powerful, easy-to-use, and best of all, cost effective.
Safe and reliable: The ME Series is ETL Listed to the stringent requirements of UL/cUL 458 and CSA C22.2 #107.1-01, ensuring that the inverter is safe and reliable.
Easy-to-install: Install the ME Series in four easy steps: simply connect the inverter’s output to your distribution circuits or electrical panel, connect your shore power cable (AC) to the inverter’s easy-to-reach terminal block, connect the batteries, and switch on the power.
