Just replaced inverter because i kept getting a fault light when i tried to use it. Now i keep getting a batt. Low red light. Batteries are less than 1 year old. Any ideas??
VERIFY that the 12 volt Positive cable is HOT at the Inverter. That means checking the 250/300 amp in line fuse is GOOD. Do NOT have 120 power to the RV when doing this. Also verify that the Inverter Battery cables are indeed connected to the Coach Batteries securely. Doug
