Photomike's avatar
Photomike
Explorer III
Oct 21, 2017
Majestic 19G - Weigh in
Was on my way camping the other day and came upon a free scale so decided to weigh the rig. Waste tanks empty, water tank almost full, fridge full, a medium selection of clothes and camper gear. Two bikes on the rear rack & my son and I in the vehicle.
The heaviest added thing on the RV was my electric bike on the back bike rack and that thing weighs a lot.
Front - 1570 kg or 3462 lb
Rear - 2670 kg or 5887 lb
Both - 4240 kg or 9348 lb
Door sticker from Rv manufacturer says max should be:
Front - 1837 kg or 4050 lb
Rear - 2760 kg or 6084 lb
Wish I had the weights from my truck camper when I had it.
  • j-d's avatar
    j-d
    Explorer II
    I'd guess that this 19G handles pretty well on the road. That's based on percentages.
    Ford's percentage for Front Axle to Total Weight is 32 pct and these number show 37 pct.
    Others feel strongly that the Front Axle should be at least 75 pct of rated capacity and this one shows 86 pct.
    That's why I feel it should steer and track pretty well even with the short wheelbase of 138 inches.
    But... What I don't like seeing is 97 pct of Rear Axle Capacity. This is common on Class C's. Rear Capacity nearly all gone but a decent amount left in Front.
  • soccrman wrote:
    Mike,
    Not trying to hijack the thread but what do you think of the 19G? Did you buy in Calgary?
    PM if you have the time, will be much appreciated
    Cheers,
    Dave R
    No Problem, will PM in a few minutes.
  • Mike,
    Cheers,
    Dave R
  • Seems the state truck scale near my house is always closed. that being said, the digital readout always seems to be on, so I drove the MH over it the other day. Both axles partially loaded, 11900 lbs total. Max is 14500 so I should be good. Weighed the trailer, 1160 lbs, max 3000lbs. good their too. turns out my E350 van ended up at 7950.
  • Snowman9000 wrote:
    How big is the gas tank and how full was it?
    Not sure of the size but would have been full. What I pulled off the net says 35 gallon.
  • DrewE wrote:
    I assume these are in kg, so that's about 3470 lbs front, 5900 lbs rear, and 9370 lbs combined, right? If so, it doesn't sound out of line to me.
    Updated it, must have been kgs or the RV weighs close to what I weigh :B :B
  • DrewE's avatar
    DrewE
    Explorer III
