Matt_Colie
Dec 18, 2013Explorer II
Mobile,
You have at least three issues here.
1 - That vinyl line with braid reinforcement is usually not for drinking water as it contains lead. Read carefully before you buy.
2 - That same vinyl is also not usually rated for hot water service.
3 - That vinyl has relatively high creep. With time the clamps will get loose and leaks will start. So don't put any joints anyplace you can't easily sung up the clamp.
Matt
Matt
