Old-Biscuit
Dec 18, 2013Explorer III
RV water system........
If installing a toilet sprayer.......suggest it come off downstream of toilet water valve so that pressure is on sprayer only when flushing toilet (diagram shows it coming off prior to toilet...full line pressure on sprayer-----can leak)
Use 1/2" braided line on pump discharge so pump is not rigid.
For the rest of system........1/2" PEX (otherwise you will be chasing leaks at those hose clamp/fittings with the braided line)
