SFVdave
Jun 21, 2013Explorer
No cutting or opening it up, only drilling 8- 5/16" holes surrounding the window frame for the fastening bolts. Could even use some sort of raised wall pass thru device for cables. Sealed it to prevent any leaking at the bolts if water should enter thru the outter seal. Add weap holes at the bottom for draining if water does come in thru the outter seals.
38,782 PostsLatest Activity: Aug 31, 2026
