BTPO1
Mar 13, 2014Explorer
If you have an inverter in your MH you should have AC voltage available to use. The inverter takes the 12 volt DC from your batteries and changes it to 120 volts AC.
Some new vehicles do have an AC receptacle for use on them since an alternator does generate AC, then it is run through a rectifier or diodes and changed to DC for use in a 12 volt system. JMT
38,777 PostsLatest Activity: May 20, 2026
