GrumpyandGrandm
Mar 14, 2014Explorer
All you should need to do is turn on the inverter. Our 1800 watt works fine going down the road and even does a good job with the engine not running using the 4 batteries we have in the coach. What are you trying to run on 110? If the previous owner installed it correctly, depending on it's watt rating, it should only be connected to a couple outlets.
Your alternator should already be connected to the coach batteries to keep them charged while you drive.
38,777 PostsLatest Activity: May 20, 2026
