copeland343
Mar 14, 2014Explorer
You are likely to overheat the windings in your alternator. Alternators are not designed to run with a heavy load for extended periods of time. Also the bigger the load you have on your alternator the harder it is to turn and is rough on belts and pulleys and wiring.
38,777 PostsLatest Activity: May 20, 2026
