OldRadios
Mar 17, 2014Explorer
The Samsung replaced a Sylvaina TV with the viewing angle problem in the bedroom. The TV is on top shelf at the celling and not tilted down. No problems watching it from the bed.
Edit - Additional Samsung 12V adapter information added:
If considering purchasing one of the Samsung TVs, the RadioShack #270-052 enercell car power adapter with the "T" tip (# 273-0332) fits the DC input on the TV. The 12V adapter has an on/off switch in the end of the cigarette lighter plug so you can switch off the DC power to the TV completely without having to unplug it between uses. The TV does not seem to loose it's channel or input memory when the power is cut so no set-up is needed each time you plug it back in.
Keep the AC power supply handy if you want to run it off shore or generator power when nor boondocking.
The power outlet for my bedroom TV has an AC plug and a 12V plug so this set up works great. No inverter needed now.
38,777 PostsLatest Activity: May 20, 2026
