TyroneandGladys
Aug 29, 2012Explorer
garyhaupt wrote:
A generator is ok...not my cup of tea, but for many, it's a must have. But..if you are looking at an on-board genset..that is a huge amount of storage room to loose. you can get a nice Honda or Yamaha that will stow nicely and not rob you of all that space. You can't run an a/c with the smaller Honda/Yamaha tho, unless you get two.
Gary Haupt
A generator running while driving allows you to run the rear AC. Not an issue if you are not going to be in hot weather or if it is only two people and they are in the cab. If it is over 90 anyone in the back will need AC. Yes you can build a rack to hold your portable generator so you can run it while driving, did it on our first RV, but it is a hassle. Plus the rack you build to hold the generator would give you close to the same amount of storage as the built in generator space.
