RVER
Oct 10, 2013Explorer
Thunderingquiet I totally agree about Tiffin but as many slide outs is not a good idea, they weigh too much and each has a potential for failing. Also you want your storage to be pass thru as much as possible and have it on rollers so you can pull out the roller drawer and have all your stuff in front of you instead of not knowing what is hiding way inside. Also if the storage door is under the slideout it can be a problem crawling under to get to the door and then definitely need those roller things. Tiffen does make a nice unit and supports it like no other company, I will never understand why they built units with a diesel engine up front!! BUT if people buy them they will build them I guess.
38,782 PostsLatest Activity: Sep 02, 2026
