Tinstar
Jan 26, 2017Explorer
BigRabbitMan wrote:
That is a base model and it is working just as it was designed. Do you know if it has a rain sensor so that it will close automatically if rain is detected? You will have to go up on the roof with it open to see if that is incorporated into your model or not since you do not have the manual for it. Right now, I think probably not as there is no such indication in your picture.
I would almost agree with you BigRabbitMan, but I can not imagine the vent lid motor running continuously after it is turned off and then back on. That would make no sense whatsoever. I would also think that I could open the vent lid with the fan speed turned off and then turn it on and it should work extracting air. Presently, the fan motor must be turned on when you are opening the lid.
There is no rain sensor.
I've emailed Fantastic Vent and hopefully they will respond.
38,782 PostsLatest Activity: Sep 10, 2026
