dougrainer
Jan 27, 2017Nomad
On top accessed from the roof is a metal pin switch(looks just like old automobile door pin switches) that closes the contac (ground) to run the fan. usually, that pin switch gets loose. You use a 7/16 wrench and tighten the pin switch to make a good ground contac. That pin switch is what stops the Fan motor from running when the lid is closed. Odds are you have a bad control board. Fantastic will supply a new inner housing with the switches and control board. If free will depend on if it is more than 5 years old. Doug
38,782 PostsLatest Activity: Sep 10, 2026
