ron_dittmer
Jan 06, 2018Explorer III
midnightsadie wrote:You are right, it does have a frame. But the frame is thin hardened steel, two "U" channels glued together to make a "box" frame. They call it a uni-body design because the front cab is integrated into the frame. No welding is permitted or the steel looses it's strength, one reason why the wheel base of a Sprinter is not allowed to be modified like an E-series. Outfitters like motor home manufactures are not even allowed to drill a hole into the frame. So if the box frame is damaged in an accident, the vehicle is quick to be totaled.
I,ve been under my sprinter and there's a steel frame from front to back. looks plenty strong to me. my coach is a LTV all fiberglass.
CLICK HERE to see many pics of a Sprinter cut-away chassis I seen at an auto show a few years ago. Also is the Transit. Note how the Sprinter frame and cab are integrated. An E-series, the frame passes under the cab with the cab bolted on top of it like a truck.
In the pics, note the two "U" channels that make up the box frame.
38,778 PostsLatest Activity: Jun 10, 2026
