tom311 wrote:
as I figure it,if you get 11 with gas and 17 with diesel and then pay 60 cents more for diesel its pretty much a wash.so why would you pay 20,000 more for a Mercedes diesel class c? especially if you don't tow anything.???want to make right decision so your input is appreciated.
Your just scratching the surface with questionable numbers. Do you want a smaller more nimble RV? Do you want something very roomy with big tanks and elbow room? Do you like the work of certain builders (coach quality is important)? How many miles are you planning to use it per year? On and on. All this stuff is expensive, all takes a depreciation hit. Fuel cost is a consideration, it is the second highest cost associated with new RV in most cases.
I could easily recommend a Sprinter based RV or a Ford or Chev based RV. Depending.
