Gjac
Jan 17, 2015Explorer III
MH test drives
Last week I test drove a 2009 National MH and a 2013 Tiffen MH both on the Ford chassis and 32 ft long. Both had plenty of power (13 sec from 40-60 mph). I am in Fla so I could not test them on any hi...
lanerd wrote:Gjac wrote:lanerd wrote:This was my thinking several years ago also. I bought this MH 10 years ago when I retired to see if this hobby was for me and learn about MH's and just thought the logical transition was to a slightly bigger DP because my wife would never want to full time. Thinking and people change. 10 years and 80k miles later she is now less likely to part time. I like the shorter lighter MH's not only for camping but for power. The DP MH's I tested did not perform as well as these short gas MH's which is another thing that I would have a hard time getting used to. My friend has a 36 ft 2012 Tiffin Phaeton and he could not keep up with my old 454 on hills on our trip to Branson Mo. I think a 340 or 360 HP gas MH that weights 15k lbs will always have better performance than 330-360 MH that is closer to 30k lbs.
When we got our first MH, we were looking at different make/models of 36' gassers and like you was very disappointed in the noise of the engine at anything over 3000 rpms. It was suggested to me to try out a 36' dp, so we did. Wow, what a difference. We could carry on a normal conversation at any time and any speed. There really is just no comparison.
Ron
It's all about weight to power ratio. My first mh was only about 80 lbs per hp and it went up the hills quite rapidly. Our newer mh is closer to 100 lbs per hp and yes, it does seem to be a little slower on the steeper grades. However, I still get to the top and if it is a couple of minutes later...no big deal...right? At least I go up in relatively quiet vehicle (at least, inside) and in a much smoother and much more comfortable surrounding.
To each his own, of course. Good luck in whatever you decide and if you come by Newport in your travels, be sure to stop and say Hi. I always have a cold beer for my friends here on rv.net.
Ron
