NOWANTSNOWARRAN's avatar
Sep 26, 2022
Michelin vs Toyo tires
I recently purchased 2006 Monaco La Palma. 24,000 miles. Great coach. Had Michelin tires on it but datd code was 2005. I did a lot of internet research and bought some Toyo m154's. The coach was a great driver on Michelin's. I drove home after the change and it was terrible. Wandered and rear swayed terribly. Did another internet search and learned about sway bars, quick fixes and safe t steer. I checked under the motor home and was disappointed to discover a safe t steer and upgraded anti sway bar.
Did I screw up? I'm considering going back to Michelins. This was a really expensive mistake if I have to replace the Toyos. Any thoughts?
  • Did you check the tire pressure? Over inflated brand new tires will do that.
    On my 2004 La Palma with Michelins I run 90lb all the way around. Based on my weight the tire pressure chart calls for 85 front and 80 rear so I add a bit for a margin of error.
  • I had exactly the very same experience. Originally ran a set of Toyos and they were fine and after they wore out, bought another set. They were all over the road immediately and I went back to the dealer and they installed a more expensive steel belted radial Toyo tire and they too wandered all over the road.
    Finally, out of total exasperation, I bought a set of Michelin XPS steel belted radials and they run PERFECT.
    Many people will swear that the Toyos are the only tires to have but I know what I know and I don't have time to be chasing the "right tires". I know what works and what doesn't.
    On a side note, I was told that tires, when new, need time to break in and once they are, will not be squirrely.And yes, my rv already had newer Bilstein shocks and Helwig sway bars.
