ander
Jul 05, 2015Explorer
My Roadtrek wrote:
You might want to read this, has some good info.
http://www.justanswer.com/small-engine/6xhx0-onan-microlight-2800-generator-it-s-carburetor.html
I agree with the Tech. if the carb. is gummed up, you will never get it clean no matter how much Seafoam you run through it. That will just prolong the inevitable, replacing the carb.
Exercising the gen-get is even more important since ethanol has been added to the gas.
Installing a fuel cut off, and running the carb dry will help when not being able to exercise per Onan's recommendations. Exercising is not just for the carb. though, it's also for evaporating water inside the engine.
im hoping of course that its not time for a carb replacement...the gen runs perfect otherwise....except for creating its own stealth smoke screen.
38,767 PostsLatest Activity: Sep 19, 2016
