rgatijnet1
Mar 02, 2018Explorer III
CVD wrote:
Interesting discussion - is "adjusting" the generator commonly needed? Of course I change the gen oil and air filter, but haven't known of other needed maintenance.
You can only tell if it is needed by using a meter to monitor it. I'm guessing that every generator is different. I keep my meter plugged in at all times so that when the generator is running, I can tell at a glance if everything is OK.
Sort of like checking shore power to insure that the voltage is not too low or too high. The same meter will do that also.
38,776 PostsLatest Activity: May 15, 2026
