Dutch_12078
Mar 02, 2018Explorer III
rgatijnet1 wrote:CVD wrote:
Interesting discussion - is "adjusting" the generator commonly needed? Of course I change the gen oil and air filter, but haven't known of other needed maintenance.
You can only tell if it is needed by using a meter to monitor it. I'm guessing that every generator is different. I keep my meter plugged in at all times so that when the generator is running, I can tell at a glance if everything is OK.
Sort of like checking shore power to insure that the voltage is not too low or too high. The same meter will do that also.
I agree a freq meter is certainly the best way to check and adjust the generator. I'd also repeat that the OP's symptoms are a classic microwave frequency issue that is not likely to be caused by any other generator related condition except frequency. A high or low voltage will not do it, although it can certainly cause other problems.
38,776 PostsLatest Activity: May 15, 2026
