Lt46
Dec 10, 2016Explorer II
This (hopefully) takes you to the eBay site that I ordered my tranny cable from.
http://www.ebay.com/itm/FORD-F53-F6TZ7E395AA-SHIFTER-CABLE-MOTORHOME-CHASSIS-1997-108-INCHES-LONG-USA-/322319799430?hash=item4b0bc1d486
Regarding the end links. Yes, this cable has the eyelet ends that snap over the existing ball stud that Ford used. The eBay photo is decieving because it shows some type of stub attached on the end. That stud is actually a replacement ball stud should you need to replace what Ford provided. This stud simply pulls out of the eyelet.
Using the cacblecraft p/n I supplied will get you exactly what you need. I will caution you the ENSURE the correct length of cable needed by measuring the existing cable. There are 2 different cables offered by this seller and they also caution buyers to ensure the exact length needed.
Best of luck.
Best of luck.
38,780 PostsLatest Activity: Jul 05, 2026
