theoldwizard1
Mar 05, 2021Explorer II
valhalla360 wrote:wanderingaimlessly wrote:
The ones I've seen, they mounted the outside portion on the rear of the rig to allow sufficient airflow to cool it.
Yep, check with the manufacturer for airflow and spacing requirements.
This is going to be your problem !
Manufacturers specify a large margin on all sides for both airflow and serviceability. While it is possible to mount the unit on a slide out, flexing the lines will cause a failure over time.
38,780 PostsLatest Activity: Jul 04, 2015
