valhalla360
Mar 06, 2021Navigator
pianotuna wrote:
I would jump right to a 48 volt battery bank.
Agreed, once you diverge from 12v may as well take good advantage of a higher voltage.
Also, keep in mind for the spacing, that the 12" manufacturer spec you mention is likely based on the condenser being completely outside with no other restrictions. If fresh cool air can only enter from a relatively small slot from below, it may not meet the needs. Talk to the manufacturer and explain exactly what you are doing.
38,782 PostsLatest Activity: Sep 10, 2026
