Dirtyrhoades77
Mar 07, 2021Explorer
pianotuna wrote:Dirtyrhoades77 wrote:
As for 48v, I can see what you guys are saying, but if I go 48, I'll then have to get a 48 to 24 converter for the fridge, and that's another component, and it's $150.
My system probly won't ever go over 2000w, so I won't be outgrowing 24v, so I can't see any real advantage over 24.
Maybe 48v mini splits are easier to find at the moment? Are 48v alternators easier to find? What other advantages are there besides more headroom for expansion?
A 24 volt inverter has to carry twice the current for the same output load as a 48 volt unit.
Your fridge is already 24 volt? That's a bit rare.
I've never seen a 24 volt mini split--but that probably means when I was searching for DC powered air conditioners that the 48 volt ones 'jumped up' first.
I don't have the 24v fridge yet, but jc-refrigeration.com sells replacement components for RV fridges. You pull it out, swap the components, and shove it back in. People seem to like them, and they have a 3y warranty, even up to 6 years. Best of all, no propane use and no inverter needed. I'm definitely doing that.
As for the DC minisplits, I think behind all the rebranding I think there are very few manufacturers actually producing 48v, and I've found only one so far for 24v, and I'm trying to clarify some of their info, as it's inconsistent.
38,782 PostsLatest Activity: Sep 10, 2026
