JimM68 wrote:
I'd like to cover them. With something that will stick to them and look smooth and good. I don't know where to get 4' wide contact paper, and probably lack the skills to smoothly stick down a piece that big....
Has anyone done anything like this, or have any suggestions as far as a good material to use?
In a previous life I made and installed vinyl decals. If you want to cover the mirrors and don’t want air bubbles, fill a spray bottle with water, add a couple drops of dish washing liquid. Before removing the paper backing, measure and cut to the correct size. Lightly spray the mirror with soap and water mixture. This will allow you time to adjust the contact paper. Place the precut paper in place. Use a small plastic squeegee (available at any hardware store in the wall paper aisle) to remove bubbles. This will also remove the majority of the water. Either allow the remaining moisture to evaporate or use a hair dryer on low to dry it. Sometimes a corner will not stick, if this happens, a small dab of superglue will fix it.
