Raymond Quintal wrote:
The mirrow on the drivers door is about to fall off my 2001 E450 c class motor home. It is a power mirror with a heating eliment. it appears I have to take the door panel off to get to the mirrow attachment bolts. I removed the only two screws I could find, one AT UPPER corner by mirrow controls and one at lower left corner of door panel. I tried to remove door panel by pulling out to release any clips with no results. it appears that there are more screws or some type of attachement in center of door which I can not find. anyone know how to remove the door panel or thighten the mirrow. Thanks
On my '07, after the screws are removed, "lift UP" on the panel, not out, the panel has tabs in several places that fit into holes in the door then "lock" in when the panel is slid down.
