rexlion
Nov 25, 2015Explorer
"...closer to low than full"
It's between the low mark and the full mark. No oil needed. Even if it uses so much oil in 400 miles that it dips a bit below the low mark, it won't hurt anything. You might take a quart with you, and check it about halfway into the drive, but chances are you won't need to add it.
That said, adding a half-quart of the 10W30 should not harm it, either.
38,768 PostsLatest Activity: Nov 21, 2015
