Fla904
Nov 25, 2015Explorer
rexlion wrote:
"...closer to low than full"
It's between the low mark and the full mark. No oil needed. Even if it uses so much oil in 400 miles that it dips a bit below the low mark, it won't hurt anything. You might take a quart with you, and check it about halfway into the drive, but chances are you won't need to add it.
That said, adding a half-quart of the 10W30 should not harm it, either.
Sounds good. Thanks for the advice everyone. Will do a radiator and coolant flush along with a oil change when I get it back. Already well over a grand into this thing in maintence costs and I haven't had it a full day! :E
38,768 PostsLatest Activity: Nov 21, 2015
