time2roll
Dec 27, 2015Nomad
Harvey51 wrote:Your thermostat is probably stuck open a bit.
The same question applies to engine thermostats. In the old days people would install a higher temperature thermostat to make the cabin heater work better. Now it is just too much trouble to change them. We put cardboard in front of the radiator - often forgetting it and overheating the engine in the spring. There has to be a better way.
Actually they are designed to fail open but no-one notices that... just the stuck closed failures.
Replace with OEM rating.
