gemert
Jun 14, 2015Explorer
If the transmission pad doesn't light up the engine won't start. There is a fuse for the panel, not sure what it does exactly, but others have had the problem and found the fuse bad. When they replaced the fuse the problem went away. Others have said the fuse is under the transmission pad. I'm not an expert but it seems easy to check. Good luck.
