Ivylog
Apr 03, 2017Explorer III
Why do you think you need an alignment...Uneven tire wear, pulls one direction???
You also need the ride height spec with I think is 9.5"... maybe Executive will chime in. With a solid front axle there is not much to check other than toe in. I set my own by measuring to the same spot on the inside of the tires... front and back of the tires. If it's 1/8th + a little I'm happy.
