Executive45
Jul 04, 2014Explorer III
For those that do not like yelling....Moondoggie, a new member, wrote:
Overheating issues with my motor home.
It is a Monaco, powered by a Cummins. It is a side radiator model.
Repairs made to it so far are as follows:
Radiator has been flushed and dirt blown out from the outside with compressed air, reliving the outside dirt.
Thermostats in the motor have been replaced.
Water pump pressure check done.
Hydraulic lines that come from the hydraulic pump and attach to the hydraulic radiator fan drive have had the limiter valve removed and the fan runs at a fairly high speed.
There is a 50/50 mix of antifreeze.
The radiator fan blades have an adjustment on the fan and you can adjust the blade pitch allowing more "pull", but this option has not been performed.
This has been very frustrating and I would like anyone's advice.
Thanks.
:)......Dennis
Thanks.
:)......Dennis
38,777 PostsLatest Activity: May 24, 2026
