jdb7566
Jul 05, 2014Explorer
liveneasy wrote:I agree, check the integrity of your exhaust system. I had a run hot issue last summer. The pipe from the turbo to the muffler had degraded to the point, very little exhaust was coming out of the tail pipe. I replaced the pipe and so far, no issues. Engine runs at a constant 190 degrees now, even up-hill.
While I don't have a side mounted radiator... several years back I had overheating problems, primarily on long or steep grades. The problem turned out to be two fold. An exhaust leak at the Turbo and a split seam on the charge air cooler. I'm not sure if it was one or a combination of the two problems but after the repairs were made I no longer had any cooling issues.
38,777 PostsLatest Activity: May 24, 2026
