Ivylog
Jul 05, 2014Explorer III
With a IR temp gun you should be able to check your temps when it overheats. It will let you find where there is a big change in temps. It will confirm what your actual temps are too. Start by checking the difference of the water going into the radiator and coming out.
38,777 PostsLatest Activity: May 24, 2026
